yes, there are some updates. we are going back to the drawing board a bit because these internal wastegates from atp are for the birds IMO. what I mean by this is I bought the gt3071r kit with the 14 psi spring and quite frankly it just wasn't really 14 psi. we hooked a regulator up to it and crack pressure (the point at which the gate starts to open) where you want to set sPr on my tru boost gauge was 10 psi in itself and the gate did not fully open until 23 psi. this caused boost to keep climping and not stay in its comfort zone, unless you want to set boost relatively low and spike where you want to be. all in all it was inconsistent. So I emailed atp and asked for documentation, pdf's, etc. and they said they wanted a serial number on the gate, so luckily I went through 1000's of pictures until I found one I had. They then emailed me back stating they didn't have any info. So, I ordered their 7 psi actuator thinking ok.... this is half of the 14psi they claim I have, so let me go at least half way and my gate should fully open at 13 psi or so. NOPE, THE 7 PSI GATE FULLY OPENS AT 20 PSI. If you guys don't understand, this will be hard when you try to tune for 20-22 psi.
Anyhow, I have come up with a very cool solution. I am going to get a protege garage tubular turbo manifold, and modify it to have a Tial 44mm v-band flange so I can run an external gate via v-band and run a dump tube next to my downpipe. Boost will hold, it will look sick, and it will sound amazing when the gate opens. ordering the manifold tomorrow. keep you guys updated......
