received my atp wastegate today, got it quick, ordered it on wednesday from crossover and got it friday. i shouldn't have any problems installing it with just a customSMIC and corksport exhaust, right? or should i get an afc first?
you wont be messed up by not having one but they only help. by tuning your car to respond to your mods you will only be taking full advantage of the money you put out. I was told and it makes perfect sense to me that the ECU is programmed for the stock parts on the car. when you add aftermarket parts that work better than the stock ones they will not mess things up but the ECU will only use them up to the performance level of the stock parts. by tuning with a piggyback or afc you can access all of the benefits of the aftermarket mods.
