Well, the reason I asked is that with most any strut suspension, when you remove/replace the strut, you end up with a slightly different camber adjustment than when you started.  This is important because a different camber == altered toe.
It is a fact of vehicle geometry that when camber is altered (whether by intentional adjustment or by slight change in orientation of bolts/etc when you put it back together), toe is changed as well.  Specifically, putting the car back together with more negative camber will cause toe-out while putting it back together with less negative camber will cause toe-in.  This is if the tie-rod connects to the wheel upright in the usual fashion, in front of the axle.  If the tie-rod connects to the upright to the rear of the axle, the effects are reversed.
Since the Mazdaspeed3 has a no-camber-adjustment bottom strut attachment, the only room for camber change when reinstalling is if things go together in very slightly different orienation... like if you loosen bolts and wiggle things a bit then re-tighten.
No car I have ever seen requires loosening the tie-rods (which directly adjust the toe) for a spring install but you will have to re-align if the camber gets the slightest change.
Regarding caster, the proper way to check it is to take camber readings at varying steering angles.  This allows you to calculate caster based on how the wheel changes camber just from steering.
