How-To: Install Cobb Springs + Impressions afterwards.
Sacrilicious
boom boom!
Cosmic Blue MS3 of hawtness!
I just put in my Cobb Springs last week, and I figured that we've been long overdue for a spring-specific How-To here in this section, since it's such a common mod that can potentially be very annoying that many people will be interested in doing. It took me roughly 7-8 hrs to do this because I was learning by trial and error, so I'm going to try to speed up the process for anyone else out there who is new to spring replacement! Special thanks goes out to blacksheepms3 for being such a good sport and helping me learn the process on the first strut! (alright)
Let's start off with a list of the tools that you will want to have handy for this:
1. Mechanics Gloves (this will really save your hands from some annoying scrapes)
2. Jack
3. Jack stands
4. Stock Scissors Jack (I'll explain later, but this is ESSENTIAL for sanity purposes)
5. Ratchet set with 14mm, 17mm, 19mm sizes.
6. Ratchet extension.
7. Adjustable Wrench
8. Torque Wrench
9. Allen Wrench
10. Breaker Bar
11. Pliers
12. Flathead Screwdriver
13. Spring Compressors (for Macpherson struts)
Here's some things that will keep you sane when it comes to removing the stuff:
1. PB Blaster Penetrating Catalyst (spray lubricate and anti-corrosive)
2. Anti-Seize (silver goop...looks like Arctic Silver...ESSENTIAL lubricant)
For torque specs, please go to this site: http://www.mazdaclub.net/mz3ws/
Make sure you torque things back to the ratings that they are specced for when you put stuff back on! Be careful about following the instructions there, because some of it is very unnecessary and will only cause you undue pain and suffering.
As forewarning: the front springs are much more annoying to replace than the rear ones, so I would suggest picking which set you want to do first based on that. I'm going to explain in the order that I did things in (front first rear last).
Let's start off with setting up for jacking the front wheels up...
1. Pull your parking brake tight and put wedges under your rear wheels so that there's no chance that it will roll away and squish you.
2. Break your tire nuts loose before jacking the car up.
3. Carefully jack your car up in the front left and right and support using jack stands.
4. Unbolt your wheels and set them to the side.
After you're doing clearing stuff out, your going to want to remove the ABS sensor as noted here with the yellow arrow:
After removing the ABS sensor, we will need to detach the brake line from where it clips onto the strut itself. This requires that we first remove the retainer clip that holds it in place and then push the brake line downwards to disconnect it from the metal enclosure it is sitting in. Here is a picture of the retainer clip you will need to remove with some pliers:
After this, you will want to disconnect the upper nut of the stabilizer control link as seen here:
Remove the metal piece that fits over the control link now that it is unbolted and push it to the side. Now, you will be removing the shock absorber lower bolt that holds the bottom part of the strut in place on the control arm. This is a 2" long bolt that is located here:
At this point, you are done removing bolts in this bottom portion of your shocks. All that remains is:
1. Detach the bottom part of the strut from the control arm.
2. Unbolt the top of the strut from the engine bay.
3. Pull the strut out of there.
In order to detach the bottom part of the strut, I tried a number of things. At first, I did what the shop manual wanted me to do, which was to bang the control arm with a hammer to break it loose and out of there. This is NOT a fun idea, and it's really not very efficient either. Here is the easy cheater's way to do it:
1. Spray the joint of the strut/control arm area with PB Blaster.
2. Let this set for a few minutes and then respray some more.1
3. Use the Scissors Jack to pry the control arm off like this (yes, this is the right front strut and not the left front like I've been showing you all along):
This part of the operation is a LOT easier with 2 sets of hands, so have someone hold the scissors jack in place (especially the bottom portion, because that tends to slip out). Carefully jack the lower control arm off the bottom of the strut and then unbolt the top of the strut from the inside of the engine bay by unfastening these 3 bolts:
Make SURE you only undo these 3 bolts and NOT the one in the middle, because that one holds the strut together, and if you undo it without compressing the springs, it's going to fly out and kill something! (eek2)
Now that you have these unfastened, you can just carefully pull the entire strut out of the wheel well.
Unfortunately, I forgot to take some pictures of the strut with the stock springs in it, but here's what it looks like with the Cobb spring in place:
In order to remove the spring from the strut, you will have to compress the spring using the spring compressor (which just turns out to be two sets of clamps that squish your spring together to take pressure off the top of the strut so that you can safely remove the nut holding it in place) and then remove the nut from the top of the strut after you have compressed the spring enough such that it can be shifted around in place. When compressing the spring, make sure to tighten the clamps evenly (few turns on one side and then few turns on the other) and make sure that you have compressed the springs enough.
I cannot stress enough how careful you should be when doing the spring compression and removing the nut at the top of the strut, because this is the one point in our install where BAD things can happen if you're not careful. Make sure that the top and bottom of the strut is pointed at things you do not value, and keep your appendages in safe places as you do this! (eek2)
After you have removed the top nut and then taken out the spring, the strut should look something like this:
The stock spring looks like this compared to the Cobb spring:
Now, in order to put in the Cobb spring, you do the following:
1. Compress the Cobb spring with the spring compressors.
2. Reconnect the top nut.
3. Remove the spring compressors when the nut is in place.
Be careful as you compress the Cobb spring, since you want to compress it in a way that makes it fit within the strut, so it's probably best to do the compression with the spring seated as it should be in the lower portion of the strut. When reattaching the top nut, be careful, since it requires you to use an allen wrench to hold it in place as you use a wrench to tighten it:
Now that you have the strut fully re-assembled, you will have to put it back in. Here's how:
1. Lube up the bottom portion of the strut with Anti-Seize so that it will slide easily back into the control arm fixture (wouldn't hurt to Anti-Seize this too) on the bottom.
2. Put the strut back into the wheel well and get it seated in the control arm. You will see that the control arm has a slit in it that the metal tab coming out of the bottom of the strut needs to fit into. Line this up and start the seating.
3. Bolt the top of the strut back into the engine bay...make sure that the holes line up, because it's not a perfect triangle for the bolts on top.
4. Get your jack underneath the control arm and jack it up so that you push the bottom of the strut back into the control arm.
When pushing the bottom of the strut back into the control arm, I found it really helpful to just jack up the control arm a little bit at a time and then use a flathead screwdriver to ply that slot in the control arm open a bit to allow the strut to slide in:
After the strut fully seats back in, you just have to rebolt everything in reverse order:
1. Shock Absorber lower bolt.
2. Control Link bolt.
3. Brake line retainer clip.
4. ABS Sensor.
5. Wheel.
Repeat for the other side, and you're done with the front springs!
Now, we go to the rear springs. It was starting to get dark out as I did these, so I was pretty lax with my picture taking, but I believe I took enough to get the point across.
Jack your car up in the rear:
1. Make sure the car is in gear.
2. Put wedges under the front tires.
3. Break the wheel lugs loose.
4. Jack up both rear sides and support with jack stands.
5. Take off wheels.
After the wheels are off, you will be supporting the bottom of the rear control arm with your jack and removing the sway bar link here:
In order to disconnect the link from the sway bar, you might have to play around with the level that your jack has the control bar supported at. If all else fails, you can just remove the top nut that holds the link in place.
Do this for both sides and then loosen the sway bar bushings so that you can twist the bar forward and out of the way. I don't have pictures of this, but it should be easy to find the bushings (they're just farther up the sway bar).
After this, you will need to disconnect the control arm from the brake assembly by unbolting the following bolt while supporting the control arm with the jack:
After unbolting this 2"-3" long bolt (it's a tight one, so make sure to use the breaker bar), you will likely have to knock the control arm loose with the rubber mallet. Carefully power the control arm and drop the spring out so that you can replace it with the Cobb spring. The stock rear spring looks like this when compared to the Cobb spring:
When you remove the stock spring, there will be a rubber cover over the top of it...make note of how it seats on top of the spring before removing it and putting it on the Cobb spring. Put the spring back into the spring enclosure thusly:
Make sure that the spring seats properly on the bottom and then support it with the jack as you rebolt the control arm back onto the brake assembly. Rebolt the sway bar link and then retighten the bushings.
Repeat for the other side and now you're done with the rear springs!
With just the springs in, I've definitely noticed a number of improvements in handling and power delivery.
First of all, the car definitely has less body roll on hard cornering. It's probably not as much of an improvement as if I had just the sway bars in, but it's definitely noticeable. I also noticed that the car definitely recovers from suspension compression faster. This is especially noticeable when coming out of a turn and over undulating bumps on the highway. The ride isn't terribly rougher, but I definitely can tell that I am settling after a rolling bump on the highway with a more solid "thud" than before. This means that I don't feel like I'm floating up out of my seat as much when I go over bumps. The car feels noticeably more "connected" to the road at higher (50+mph) speeds.
In addition to settling faster, the springs have also had a very good effect on wheel hop/wheel spin. I used to have really bad wheel hop in 1st and 2nd gears after switching to these light 16" wheels, but things have improved a LOT with the springs in place. The comparatively stiffer suspension in the rear shifts the weight of the car slightly more toward the front and allows me to get more traction on takeoff than I used to have. The wheel hop is almost gone in 2nd (except towards the higher rpms) and much more controlled in 1st. Wheel spin is also reduced, so I am wasting less time wearing down tires when I floor it in lower gears.
As far as comfort goes, I didn't really notice an appreciable increase in road noise, but I definitely noticed that the ride is stiffer/rougher (especially over rolling bumps). Overall, I don't really find this to be too rough for a daily driver, so I'm very happy with the tradeoffs that I had to make in comfort.
Unless something drastic happens, I would definitely recommend going with the Cobb springs if you're considering it. Not only do they improve the handling and reduce the "floatiness" of our cars at higher speeds, but they also improve the ability to put our power to the ground by reducing wheel hop and wheel spin. I can't compare these to any other aftermarket springs, but when compared to the stock springs, it's definitely a huge improvement. At $250, it's WELL worth the money, imo! (alright)
Here's a shot of what it looked like before the springs:
The wheels are 16"x8" rx-7 FD wheels @50mm offset weighing 16lb each. The tires are 225/50/16 Michelin XGTs (all seasons). I use these wheels because they really help with ride comfort and actually handle quite well, all things considered...=d
here's the after:
the 2nd pic is taken from closer to the ground, but if you take things in perspective, you can see about 1" drop in the front and 0.5" in the back or so...=/
Excellent write-up!! I will definitely have my laptop close by with this thread open when I install my Cobb Springs in a month or so (weather permitting). Seems like it will be very similar to swapping the suspension in my old car, but your little tricks are definitely gonna be helpful.
Can't wait to see the after pics. Good choice on color btw.
Thanks for the great write up. I have been waiting for someone to do one on the Cobb springs. Why not take a picture of the car with the Cobb springs installed even if they haven't settled yet? This writeup makes it seem so easy, like it would only take few hours. I guess I'll have to order them soon...
Thanks again! - Great work.
done now...=d
it took me a fat freakin 8 hours because i took FOREVER to get the first strut off the car, but after i learned the trick, the 2nd one took <1hr to do. the rears were no more than 1-2hrs, so i imagine 4-5hrs total knowing what you will know with this tutorial if you're not experienced with spring replacement...=d
oh, and do yourself a favor and dressed really warmly if you're doing this in the frigid cold, because i've been laid up for the last 2 days from this install...(sick)
Outstanding tutorial! Seriously.Great detail and photo, report card on results are helpful too. Were you also going for sway bars? thank you, Cobb springs for dummies (me) succeeds.
ya, i actually already put in the rear sways (about 1 hr in a dark garage using a flashlight), but the front sways will require some extra time, since it actually requires some serious removal of undercarriage parts. i'll be doing that some weekend in the future when it's not freezing cold out...=d
cobb ships an instruction booklet with the sways, though, so it helps a whole hell of a lot. the reason i put the springs and sways in separately is because even though i ordered the full stage 2 suspension, they didn't ship together, so i had to wait for the sways after i had the springs in.
Yea remember you saying about delay w/bars. I'm still hanging out on this subject. I think I want stiffer springs than Cobb, but it seems that a dedicated Tuner might provide an educated, track tested package that creates a worthy road car, able to deal in a high speed and extreme cornering environment. All for a reasonable price. haha. Point> I am looking forward to your impressions on stage 2results.
Thanks for the right up... Just did the install today, it was a huge help. Thus has been the biggest thing i ever did to any car and i have to say it was a breeze. (band2)thought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
i'm glad that this was a help! this community has given me so much, so i figured it was high time to give something back! ;)
Does Cobb suggest a post-install alignment check is mandatiry ?
i seem to think that cobb does recommend somewhere that you get an alignment after the springs settle. as the springs have settled, i have actually noticed that my rear camber is very noticeably negative (this means that the tires lean inward, which leads to uneven treadwear). to fix this, i will be getting the mazdaspeed rear camber links to fix this up in the next week or so, so i'll give you guys an update as to whether there was anything weird with that particular install. fortunately, the rear suspension looks pretty straightforward, so i don't foresee anything major with putting them in.
ok...thanks to tagkat, i figured out that the fact that the rear wheels have pretty noticeable negative camber is nothing new. stock ms3's come with a pretty negative rear camber (i checked with a few new 08 ms3's in my dealer's lot to be sure), so it really has not changed with the addition of the cobb springs! :D i will definitely NOT be getting rear camber links, and it looks like all i'm going to do is get my alignment done in case of toe changes and then call it a day...:D
Good write-up, man. The drop looks nice. Put back in the 18's in the spring and it'll look great. You're welcome, man. I'm here to help a brother out.
That looks nice even with the winter set up. Once you put the summer ones back on it will look badass. Nice writeup aswell.
Similar Threads and Articles
