I put my deposit down at the dealer, It will be picked up after work on Monday!!!
did the back brakes, it was a b**** too because i didn't know about that tool you have to use to push in the caliper piston, spent about an hour tying with a c-clamp before calling a friend to tell me about the tool. damn i was pissed. oh and also my steedspeed mani should be here in about a week and a half!
cleaned car for show tomorrow and used mr. clean magic eraser on headliner that worked miracles for me. That thing was soo dirty.
s***, how bad? dibs on MAF, Forge WGA, and exhaust in case of partout! lol jk seriously i am kidding, making fun of all the vultures on this site that look for posts about accidents to get discount parts.
It's not bad, just got the passenger side 1/4. I was behind the guy and started switching lanes, when he decided to turn without signaling, I didn't see he was braking b/c I had just checked my blind spot and bam...
I have the headlight, the rad. support is junk, 1/4 panel got pushed to the door, fender-well bent some, and the hood has some spidering. The worst part is the bumper cover is junk, which I had spent a LOT of time fixing this winter, cutting, reglassing, sanding, more sanding, and then expensive paint, and its ruined now...
Pics maybe...
http://www.facebook.com/album.php?aid=2001894&l=b3a7c&id=1601010018
I just replaced the plugs today for the first time on my MSP. I switched from the stock NGK's to the V-power which are much cheaper than the OEM ones, and so far they seem yield a more aggressive combustion. Goodstuff. $8 for the whole set from Advanced Auto. I also replaced the stock rear sway bar bushings with the Teflon coated E series from the stealership. No more squeek(for now).
Ordered an AEM cold-air Intake system which should arrive next week.
installed my forge BOV but i dont know how i could have messed up but i guess i did, turkey is still there! damn, any ideas, im thinking it might be the spring, what color spring is used for stock psi? i bought it used from a forum member.
are you running the dual setup? i assume you did not relocate your maf based on the pic in ur sig?
Congrats, man. That looks awesome. Except for those tails. They make me cry tears of blood and pain. Don't wait to smoke the stock tails, get them on ASAP.
Sorry to hear it man. I've been there before in my MSP. It's a really bad feeling...
I'm in no hurry. lol. just gotta get it the way I want it eventually. for now, money is the bigger demand, and the stock tails are still in the physical possession of the former owner...
installed 626 mani. and pg sticker. I like these stickers much better than the outline ones he had.
the mani is great so far. I was running 10.5 with the supermap cause i cant log the AFR at the moment (thanks autometer). so i havent tuned it. but now im at about 11.3's woo hoo. lol
just need to fine tune some areas.
i hardly lost any throttle response or low end power, and got a really nice gain up top. Install went well, only had one snag and that was i had to adjust the throttle cable tension, but that took like 1 minute. i remember reading about he install back in the day, people make everything sound worse, you barely have to move vac lines, and u certainly dont have to take the stock mani apart to remove it...
