ok i just check my dh logs and all is good. AFR was 10.3 at 4762rpms. So i guess i must have missed it. Its hard to watch the gauges and road haha.
i see mid to low 12's under boost...is that to lean?
if you are using a wire in 'air/fuel' gauge you are only using the 1v factory sensor which reads lean or rich and nothing more than that. a wideband sensor and gauge reads from a 5v range and can pinpoint your exact air to fuel ratio in terms of a numerical reading. 14.7 to 1 is considered "stoichiometric" or normal for most operating conditions. a smaller number such 12, 11 or 10 to 1 is richer and a larger number indicates leaner.
