Clunking From Rear End
ED.T
when Ever Going Over Any Bump Or Even Ruff Roads I Keep Hearing Clunking From The Rear End Anyone Else ?
DUDE!!!!! I have the same thing!!!!! Are you on the stock suspension or are you lowered. Mine kinda sounds like the spring is moving around back there a lil bit. Like a crunching sound.. hard to describe really. Its only in the back.. and then I have a jingle sound up front. It all started when I rotated my wheels a lil while ago I do believe. Kinda weird. And it would be way to convenient or coincedencidal (sp??) for both rear shocks to blow out at the same time. Its kinda weird. I checked the rear sway bar links and everything else without taking the wheel off and everythings tight. Again.. really weird.
Stock.There's another thread that said it coming from the rear sway bar i'm gonna check mine today after work
FYI, I had that happen on my 07 about a month after I got it, over a year ago. The nut on the passenger side rear sway was loose enough to be unscewed with my fingers. Get that bad boy tightened up and see if it goes away.
Also make sure to have the tech inspect the endlink for damaged threads. I had mine replaced (for free, natch')
