MazdaSteve3
I just had a look at the intercooler cover, and I think you have probably hurt your on-road performance. It looks like the cover is designed to fit closely around the finned core of the ic and direct all of the air through the core, and prevent the air from flowing around the outside of the intercooler. On the underside of the cover, there are foam strips that seal along the end caps. There is no foam along the left and right sides, but it is a close fit, and there isn't much gap. Air flowing through the core is good, air going anywhere else, not as good.
You may have indeed improved cooling on the dyno. If your hood was up and no air was being forced through the core, then exposing the end caps of the ic might allow a relatively significant increase in cooling. If you had a box fan on top of the ic, cooling would have also been improved, since the fan is plenty large and there would be some cooling of the end caps in addition to the air flowing through the core.
There may yet be some opportunity here, though. The grille opening stops 1" short of the back end of the core, and 3/4" short of the front end of the core. These areas of the core aren't sealed off, just covered. Also, there is some small restriction to flow from the grille mesh itself. It appears that Mazda was trying to make the ic look more square by shortening the length of the opening and visually increasing the width with the 1/2" wide strip of fake grille on the driver's side, and cooling may have been sacrificed a bit. There may be some on-road performance to be gained by cutting out the mesh (but leave the fake strip, even though it is ugly) and extending the opening to the front and back up to the end caps. Sealing the left and right sides with foam might help as well. It may also be possible that this decrease in resistance to flow might be negligible in comparison to the small area of the ducting inlets. Hard to say. Happy modding!
