1992 Black 240sx with a CA18DET swap located in Indiana. The motor is fully built and is capable of handling 400+whp. The car previously dynoed at 343whp @ 20psi. Car is currently ran at 11psi with a very safe tune. Please be sure to read through the modification list to truly understand what has been put into this car.
Engine:
Fresh Build, about 4,000 miles on the motor.
CP pistons 8.5:1
Eagle rods
New stock cams
Turbo:
Freshly rebuilt Turbonetics T3/T4 63. ar
SSAC top mount manifold
New Synapse Wastegate set to 11psi. (Wastegate can be used to adjust boost levels. 8 Different settings possible)
Custom 3" Downpipe and 3" exhaust.
Front Mount Intercooler
New HKS Super Sequential Blow Off valve
Engine management:
Tuned ECU
HKS Vein Pressure Controller
Apexi Ignition Timing Controller
Apexi Safc
Walbro 255 fuel pump
510cc injectors
AEM UEGO Wideband
**car is currently on a very basic tune and it would be beneficial to have it professionally tuned.
Suspension, wheels, and Brakes:
Tenzo R lowering springs
Q45 Front brake upgrade with new pads
New rear pads and rotors
Brand new Ichiba front and rear 5 lug conversion(less then 200miles)
Dodge Magnum wheels +22
Car will come with an extra set of 300c wheels
LSD:
J30 Viscous Limited Slip Differential.
Interior:
Pioneer CD player and Newer speakers up front.
Autometer boost gauge
Corbeau Red Bucket seat (not mounted or pictured, but will be included with car)
Battery Mounted in the trunk.
6K
Feel free to email or call me (317.730.7218) with any serious questions regarding the car. I will keep this ad updated and will take it down when the car is sold. No test drives will be allowed unless you show up with money and intentions on buying the car.
Thanks for your time.
