Andy, I'm not sure hauling Miata stuff in the P5 counts as what you did to your P5, but then, I've put stuff I've done to my MPV in this thread because I used P5 parts on it, so we'll let it slide this time.
Where'd you score 4 free race tires? You know they're not free if you have to work (on your knees) for them, right?
Who calls me Andy??? Random...
One of the C-Stock guys was getting rid of them for his new ones, guess he didn't want to haul the used ones back? Anyway, he posted on soloatlanta. Said "First one to PM me gets 'em, just pick them up," so I did.
Wetsanded and cleared my cluster today after adding another pod on the right for my J&S Knock gauge! It's more red in person and actually has less orange peel than my oem paint so I'm very proud of the job I did!! YAY!
I put a full set of these on today:
R1 Concepts Cross Drilled and Slotted Rotors with Posi Quiet Semi Metallic Pads
got a tint ticket on monday :( $90 down the drain. but today I drove it back and forth to work I've gotta get it washed sometime soon. She's dirty as hell
Tein S-techs w/ the new-to-me 16x7 Flik FTDs with 215/45/40 Hankook Ventus RS-2 Z212s :)
bad phone pic, but watev. Suck it up, I'll have more later ;)
Here is a link to all the specs. LINK!
.Approx. Height Adjust Range
mm inch Max/Min(mm/inch)
-45 -1.77 -
REAR
-38 -1.5 -
SPRING
FRONT
SPRING RATE / PART No. Replacement Availability
kgf/mm lbs/in Part # Max/Min(kgf/mm-lbs/in)
3.2 180 -
REAR
SPRING RATE
2.6 150 -
valve cover off to powder coater....
valve bodies arrived...woot, woot!
