A high compression piston is taller than a standard piston, correct? If so, at what point does the engine transition into an "interference" engine? Right now, the Protege motor is non-interference in stock form (at least the US-spec motors). Not that anyone plans on breaking the timing belt, but it's good info to have.
Also, what's the compatability of the long reach NGK spark plugs and high compression pistons? Or what is the ideal spark plug to use with higher compression pistons?
