My VIN ends in 107800.
whoever told you about any 2007 models qualifying for it was wrong. No 2007 model is in the VIN range
I think the misunderstanding (I know this is what I thought) comes from the perception that Mazda made only 5000 MS6 in 2006 and that they are sequentially numbered from 0001 to 5000. Apparently that isn't the case, since 7xxx is, apparently, a 2006 build.
So one of two things: A) Mazda built more than 5000 MS6 as 2006 models, or B) the ones they built aren't sequentially numbered. Anyone know the true number built?
I'm sitting in Beach Mazda, Huntington Beach, CA. as I write.sweetness, so we get a brand new clutch out of it.... But I'm concerned on the exact type of changes that will take place. If they simply "soften" the clutch engagement, it just means more lag in power transfer and the potential of the clutch to wear out faster... ie it would only be able to support 300hp instead of say 350hp...
They're looking at my MSP regarding the clutch TSB.
They were not aware of the TSB either.
da Gaz
Mazda Huntington Beach authorized the clutch job...
Really nice about it...
Should be done around the 24th/25th...
Had to order some parts...
Loaner is Mazda3 1.8 Sport...
Now I need to find a rear bumber assembly and install it, hit for the third time in 18 months in a parking lot...
Went to pick up my car following the clutch TSB and the guy says "oh, we were just about to call you." Seems my steering rack went out during the test drive, so they are ordering a new one and it will be installed tomorrow. I'm a little upset that I paid for an alignment a month ago. I personally am not buying the idea that the rack just went out (course, I think Humpty Dumpty was pushed; I'm just sayin'). I don't think they've had a lot of experience with this TSB and I figure they probably damaged it during tear down or rebuild. Either way, more new parts!
I am going to look at an 06 and according to the vin its a type A. How can I tell if it has has this TSB addressed?
