Any photographers in here?
Guess it's time for me to post up a few of my shots:
07 TBSS
05 GTO
2007 Belle Isle Grand Prix
06 Ford GT
im trying to edit this pic, and I could use some advice. The main changes were that I messed with the color balance a little bit and increased the sharpness. How'd I do? Also, I would like to crop out the stadium a bit so the main focus is the car, but don't want to shrink the picture too much. any advice would be good, thanks!
(1st attachment is resized original, 2nd is edited)
I'd say you over sharpened it a little, and might want to brighten it up a little bit. Here's the method I use to sharpen my photos. The main thing to remember is that you only want to sharpen the subject of your photo, not the whole picture. The composition is good, and I don't think you need to crop out any more than you have already. When cropping, make sure your tool is set to a 3:2 ratio (or 2:3 for vertical) and your pictures are kept to 800x600 pixles or 1024x533 (or whatever it is with the 3:2 ratio) for best results.
- Sharpening on the unresized image. You can sharpen the original sized image lightly before doing the final sharpening on the resized image. It asks for some experimenting, but this step is not a must. You can do without it.
Fred Miranda sells Photoshop plugins which are supposedly dedicated for different types of cameras. This procedure sharpens only the (black and white) lightness layer (can't think of the correct name right now) and selects only areas with sufficient detail to sharpen. A timeconsuming process if you'd do this by hand. A very handy tool indeed.
- Selection. Deselect anything with very little detail, like the sky and dark/black shadows (which is also what the FM plugin does described above). These will only get grainy when sharpened. Use the magic wand tool to select these areas and invert the selection. Then you can start sharpening.
I notice many people don't do this, I see a lot of pictures with quite awful (unneccesary) grainy skies for example.
- Layers. Sharpen on a "duplicate copy" layer. Whenever jaggies appear, you can erase them with the eraser tool (set at small, soft diameter of +/- 8 pixels f.e.). You can also erase any grain and white halos (the white lines that appear on very contrasty edges) that appeared due to the sharpening. Heavily jagged images are a thing of the past if you use this trick.
You can create even more layers if you want to have more grades of sharpening in one picture. That's for the more advanced editors. Wink
- USM (Unsharp Mask). This is a tough one... I think just about everyone uses a different setting here, so you'll just have to figure out what works best for you. I've heard people use
-> one pass of 500, 0.2, 0 + another pass at a lower setting
-> 2, 3 or more passes of 50, 0.3, 0
-> 2 or 3 passes of 200, 0.2, 0 (which I use at the moment)
-Jeff
You oversharpened.
I use this method for sharpening:
make a layer, blend mode (overlay)
then use High Pass filter.
Easy way to sharpen photos.
as for crop, i'd crop the photo so the edge of the photo sits near your back bumper. rule of 3rds. and there's more room in the front bumper area..car pics look better that way.
OK i tried again with some layering tool... I'm not so good at photoshop yet, but im trying, any better? I think it focuses more on the car now than previously
I agree, MUCH better. Do you have a raw copy of the photo? I'd like to give it a shot and see what I can come up with if that's okay.
-Jeff
One other thing too is try to find a background less "busy" The reflections on the car are very distracting. Black cars are hard to shoot.
Like this..you can see the curves of the car, the reflections aren't creating different angles or edges, etc....
http://farm3.static.flickr.com/2263/2312065518_a417c0389f_o.jpg
very nice shot... you can check the pics in the links in my sig, i like a variety of backgrounds, none quite so stunning as that one tho. Anyway, i really appreciate the advice guys
Forgot to mention..that's not my shot. Just showin an example.
A clean horizon makes a huge difference in automotive photos. I live in Amish country so it's tough to find good open locations. I still haven't found one for a nice sun set shot
