unless they changed the design, this is the problem:
That may be true of the AWR pan. The one we use allows the GT Spec 4 point ladder tie bar without issues....and is definitely not that close to the OE cradle!
you're kidding right?That's true, although I doubt that tie bar would seriously do **** all...
you're kidding right?![]()
So Edwin what's the verdict on swapping in a spring from another pump?
Ok so before this goes off topic lets get final
info on this mod posted with shipping info address ands what not maybe pricing as full package including all lines gaskets sandwich plates seals to replace pump re-locate filter with PRV and bypass system.
Its not really about "more" flow..its about Consistant pressure and flow combined.how much more will this flow than the stock.
so are you blocking off or capping the oil pumps original bypass valve as well? Is this the reason why we would need an external bypass valve system?
.....The main reason we have found for the degredation of oil pressure over time with consistent hard use of the motor is due to the factory bypass regulator causing cavitation inside the pump.
What we have done on our race motors is render this inoperative and replace it with a bypass valve externally. This external bypass valve is adjustable as well.
