got it... so puting a softer spring helps?
mine is completly seperated from the WGA line.. both run lines to the mani and both have diffrent places to plug in.. but i still have turkey..for the stock BPV i don't think it will because the stocker should already be opened fully when the TB plate is shut, Mazda just didn't design the BPV very well. I don't know about the BS RDV though. I think I remember something about isolating the BPV from the WGA on the brake booster line to help valve response....might help with the turkey a little.
read the How-to Kill your turkey and check the section on vac line distribution
when the throttle closes and the bpv does it's job.. it opens up a hole on a big balloon of air... even if the hole is smaller than a BOV, you still open up a hole and let out pressure.. it,s like taking a REAL big balloon and blowing it up real big and then open the hole (which is rather small) what does it do? *pffffffffffffffffffffffffffffffffffffttttttt* and deflates..
why would a 1" hole in a BPV do this sound while a hole in a BOV wouldn't?
im not sticking to that theory..
if this was true, then removing the BPV from the hot pipe and leaving the hole open would do the same thing while letting to the gas (excluding the fact that i would be a leak and causing the car to run very rich that is)
there has to be something else
intresting..
the position of the bpv may also play a role..but is the sound 100% positive it's compressor surge?
maybe it's where you put the BPV vac hose that changes the equation.
the only diffrence between the hot pipe side and the cold pipe side is that theres an intercooler in between..
i just hooked my stock bpv to the brake booster. no more turkey
yeah,i just hooked my stock bpv to the brake booster. no more turkey
yeah,
1-what boost you running
2- what sound does it do ?? like a BOV "wooosh"??
3-where exactly did you hook it up? (pic please)
I don't think will sound like the BOV "whooosh" as that sound is made by the BOV...it will most likely give the BPV "pfssssh" just no gobble.
When I got my MSP, I put the Injen on, turkey out the ass.
Bought a TurboXS BOV, still turkey'ed out the ass.
Put on my FMIC, with the same BOV (but now on the coldpipe), no more turkey.
IMO, the outlet on the hotpipe is stupid. The combination of not enough flow out the stock nipple on the hotpipe, with the BOV/BPV being so close to the turbo doesn't give the car enough time to vent/recirc before the pressurized air slows the turbo down, giving you the turkey (surge). That is why the BOV/BPV should be on the coldpipe, the further from the turbo the better.
Someone with an extra set of pipes do a test. Put the same valve on the hotpipe, test, then on the coldpipe and test. Let us know what happens.
wait up here. some one could confirm if you hook up a BPV to the brake booster will remove the turkly.
can someone say that?
