well, last night I put on the Forge Bypass Valve because I just couldn't wait anymore. it's pretty great. I was kind of worried about the sound, but it's not that bad, and if you're not above 5lbs of boost (it doesn't happen that often, but you know) you just get the woosh, and no ping.
the thing that I noticed straight off is that the vent hole on the flange side of the stock valve is TINY. like not even as big around as a pencil. this is where all your boost pressure is venting. seems extremely inadequate. after putting the new valve on (which took no more than 5 minutes), I noticed that the vent is a lot quicker. the upshot to this is that there is less force on the turbo which would cause it to stop spinning, which is the whole point of a blow off or bypass valve. since the impeller is still spinning, theoretically, boost should be instant on fast shifts. I haven't paid that much attention to it, but on the whole, I am extremely happy with the upgrade.
by the way, I didn't see any more boost held or spiked. no noticeable change in power or anything. I am thinking the aforementioned would maybe save a tenth or so in the quarter (total stab in the dark) just because you're in boost quicker on shifts.
so to sum up,
woooOOOOOOSHPINGpshhWOOOOOOOSHPINGpshhhh
so to sum up,
