Speed Sensor
SilverWidow
2006 MazdaSpeed 6
Can anyone help me locate the Speed Sensor wire and possibly the Reverse wire that I could tap into? I have a 2006 MS6. Thank you for any help in advance.
Speed sensor should be connected to your wheel hub. Turn your wheel toward the passenger side to get a look at the driver side. Look just below your brakes where your wheel and axle meet. Atleast that's where they're at on most cars. You probably get a better look if you take the wheel off.
Reverse Light red/yellow + driver kick, 14 pin plug
You should be able to find a useable VSS in the radio harness, the stock system uses it for the ALC. IIRC it's green/red.
you know waaaaaaaaay tooooooo much about the wiring of this car lol
actually I look to no other for help in this area - thanks for your posts like this ssinstaller!
