These will work, right??
What is your setup. 235 on stock?
No. 235/40/18 on 18x7.5s. They look totally fine but if you looking right at the wheel, there was a small area at about 10 oclock where the tire could grab the inner fender if the suspension was fully depressed. Even after it happened to me, I was skeptical because it just looked impossible. But we tested it at the shop and it absolutely contacted. Rolling it up fixed the problem. This was with the stock suspension...
im running volk te's +48 18x7.5 with 235 40 wheels in the front and +40 18x8.5 with 235 40 wheels in the rear. no rubbing with drop and i turn hard. :)
Why would you be running wider wheels with a more aggressive offset in the back of a front wheel drive car?
So i changed my mind and i think this is final, about to order. I'm going to get the tenzo type-m in black. I found a good price on wheelsnext. They don't have the speed3 listed for fitment but they do have the regular 3 so i selected that. All the things are same for the 3 and speed3 like hub bore, bolt pattern, necessary offset, right???
