cleaned MAF sensor. Did non-fouler trick. Wanting to clean the EGR but lacking tools. Car stalls like a mofo but after driving/reving for about 10 minutes she runs fine.
Dug the fubos doorlock actuator out of the drivers door & plopped in the new one. All good now.......
Installed an OBX UDP:
There is the heavy ass stock UDP:
Here is the glorious new OBX UDP:
Comparison:
After having my dad put it in fifth gear and stomp on the brakes I was able to remove the stock and torque the new one on:
Got the belts on and we are good to go!
Comparison:
Did you have to adjust the plate on the back or not? Either way, how you like it? I love mine:)
no, the plate is just part of the pulley. Not even sure what it is for, some UDP's don't even have that plate in the back. My guess is it is in case the belt falls off or brakes it is just a guard
It's the crank sensor wheel & it has to have the gap spot in the same position as it does on the oem. They are usually held on with 3 screws to the back of the pulley. Some evidentally came with that in the wrong position & people's cars wouldn't run. Always good to pay attention to detail when doing these things & make sure all is correct or rinse lather repeat sets in.
I just raced in a snow RallyX yesterday and ir ran great. Plus there were know screwes or anything, it is just fixed to the pulley. As you can see all you have to do is line it up with the peg on the crank and it is aligned.
well, it was actually yesterday, but didn't get to post it...found that my ic clamp had broke, huge air leak...also fixed a loose wastegate...then we got to wash her...ready for the week!!(cabpatch)
I used some of that Meguirs rim cleaner today (I forget the exact name of it) $8 a effin bottle! And it worx great! Def reccommend it if ya want yer rims to shine up.
They all have it, and its adjustable, its for timing and if the missing tooth on the back plate isn't in the right spot your car wont start. I installed it right out of the box and my timing was off, I had to adjust the back plate so my car would even run, all I was asking was if they fixed their problem or if it was probably just random, but I see yours worked right out of the box. Thx.
There are allen screws on the back, don't make me dig up some pics... ;) Any retard can lign up a keyed hole, that has nothing to do with the question. Thanks anyways.
mine had to be adjusted before the car would even run. It seemed like such a small thing! it took a while to figure that out when PG was installing it
What difference do you feel as far as drive anad performance with UDP?
Mine too, I installed it and the car wouldn't start, took it off and adjusted the plate and everything was fine.
It puts back a little low end lost from switching from oem exh to a header plus the accessories are driven a bit slower. My AC works fine, the temp is no different from wp being slower, pwr steering same & alt is pushing 14 volts/lights at night just fine. Maybe all that s***'ll just last a bit longer since they're gettin a little break from the rpms. Have had no problems because of it for years.
i would say that's a pretty accurate description. you will probably have to get your alternator belt tightened once you get the UDP on too. mine (as well as a few other people's) belts squealed when the UDP was installed
