Still not sure. Tried it their way and still shorts out. Pulled it for now and will wait till the weather gets warmer. Tired of freezing my hands.
wanna come by tomorrow, we'll check it out? call me in the am around 9ish??That would be great.
Took the car to the dealer today to get the alignment checked and get the rockblocker on the side mirrors replaced. Also did the 1st oil change last weekend. What a mess. Definitely not the easiest one I have done.
Oil filter is in a pain-in-the-butt location, and after about 1 full turn all the oil starts flowing out all over the cross-member just below it, and down your arm, etc. I use a quart size zip-lock bag and put it around the filter before unscrewing to catch most of the oil, but some still drips. It's still easier to get to than a 90-97 Miata though.![]()
cool, i talked with jeremy, he was going to come by with his maf, not sure he's still coming....if you around and can stop let me know, even tomorrow is fine...i probably going to have to order one...(pissed)Had a blast today. Finally got to drive home from work with the top down. What a blast, man can hardly wait for spring.
Took the car up to Montreal last weekend and love ot on the highway. Did some hotfooting around Montreal.
Car was pretty dirty after I got home. Had to run to the carwash to clean it off.
Mark, the P5 is still on the road. Should be home sometime tonight, I hope!!.
ya, if you could bring it that would be awesome bruce!Let me know. I will bring it to the restaurant tomorrow.
thanks, jeremy didn't make it last night..i'm almost 100% certain it's the maf...No Problem
okay, from my research it appears that the symptoms i have...running good AF ratio at startup and once warm i go pig rich....could relate to the exhaust leak at the wastegate, which i'm assuming is also a "boost" leak (yes bruce, i found it behind the wastegate at the flange to the mani)...so it looks like i start ripping the turbo/down pipe off so i can get wastegate bolts, get that off and see what's going on....if your not doing anything tomorrow and want to join in the fun, i'll be in the garage by 8:30!! (boom01)Any updates Mark?
that would be great josh! hate for you to have to drive all the way up, but if you want to, i won't turn you down!!Need a hand?
