yep, using http://www.miata.net/garage/tirecalc.html you'll see you're 1.7% bigger than stock 195/50s for say a P5. So you're really doing that much better then you calculate. But in reality you should now be using slightly less gas than stock, maybe 1% or so. Of course the extra width may be eating this upSince I have 205/50 R16's, wouldn't my millage be slightly higher then I'm actually calculating? btw, I am calculating by resetting my pedometer after an exact fill up (when the pump clicks), then dividing that number by the gallons for the next fill up, and so on...
One other note on all this, if 10/32" tread gets worn down to 2/32" your diameter decreases - by 16/32 (the radius x 2) , or 1/2 inch (!) This is a 2% change. So yeah, your observed mileage does increase the farther you go...
