i seriously wish i knew why my clutch still smells 2 weeks after all has been said and done, its driving me nuts.
it did it on mine but the smell went away after a few days..
i go to jeff hass on 10 and beltway 8. I find them to be honest, meaning if they can fix it under warrenty they will, if they cant they will let you know. Good luck with who ever you go to.
YOu sir are an idiot and shoud refrain from gving any technical info what so ever...For the rest of your life.just kidding around i'm sure your car is fine you probably just knocked the clutch out of allingment or something. I don't see how doing that one thing could ruin your clutch
"Knocked the clutch out of alignment"....Thats some of the funniest sh*T I have ever heard.
where, how did you get it tuned do you have the xede or the standback
at the mazda shop. sorry man, i'm not sure if i have either.. i'm a noobie. (dunno)
what mazda shop i'm in houston too on the north side, you probably just thought you got it tuned bud. you can't get in tuned with the stock ecu. if they told you they tuned they lied
Ok hydro clutches have no adjustments to make. The pedal may have a free play but that will not help. If the free play is to tight the clutch will be slipping. The clutch can not be knocked out of alignment. It just doesn't happen plain as that. You can overheat the pressure plate and warp springs which will cause the clutch to drag or not release fully. The dealer may have reprogrammed your ecu but they did not tune it. The ecu reprograms have all been covered under recalls and tsbs.
thanks. so is there any way to udjust a clutch on an MS3 or not?
yeah your probably right, but the only thing i care is that it fixed w/e was wrong. (alright)
oh and i live nw. 290 and 6.
