- -- 03 P5 / 23 CX-5 --
Replace o-ring, go more...........
Have you figured it out yet? I paid the dealer $100 to do a compression check and leak down check. Then an additional $300 to remove the head to verify #4 cylinder is scorched hoping Mazda would warranty it. Turned out this is common problem with Mazdas and Fords but they accused me of running my engine without oil or using aftermarket oil filters. What a load of crap.
I'm burning a quart of oil every tankful of gas and is waiting for the rod to break before getting a used engine.
simdrew, we didn't hear back from you so i am assuming correcting the timing had no effect on the oil consumption? Hearing someone's first hand experience that timing had actually caused this burn off would indeed be very reassuring. I would MUCH rather re-time it than change the rings...
I recently had my timing belt changed by a shop that i will never trust again, among other issues i had with their service I suspect the timing to be wrong too, I can't imagine that causing it but it coincides exactly with the moment i had the belt replaced. Prior to that it didn't burn a single drop of oil over a roughly 3500mile period. And in retrospect, it's been feeling wierd since it came out of that service... They installed my tsudo header at the same time, if anything it should have felt a bit better not worse.
I just got the car a couple of months ago and have just recently passed the 100 000 km warranty (i'm in Canada) so i am pretty concerned... There's no smoke, it's strange, i should be seeing smoke at startup at least until the midpipe cat reaches operating temp; i see nothing. no smoke at all.
taking it where it should have gone in the first place; buddy's shop, unless the dealership/mazda are willing to let less than 2000km above the warranty slide... this is a bit premature to be burning this much oil.
5 year 100k warranty? damn i got screwed, i only had 5 year 36k warranty. bastards...
<- still burning oil and still adding more in. I'll be overhauling my oil system after Xmas so we'll see if that has anything to do with it.
I think you misread what was stated.
100k km is still 60k miles.... so, I stand by what i said, SCREWED! hehe.
ill be checking my pcv valve, can anyone direct me to a how to? i tried the search function to no avail.
my car smokes at startup. Are their any really bad side effects to worn stem seals? my car smokes at startup. will it continue to get worse?
LOL I've gone from stock PCV to Millenia PCV and then back to stock again (Millenia wasn't doing anything so...). I also have some heavy duty check values before the PCV so it never sees boost or anything. I'm pretty sure the damn thing rattled the last time I had it out but now I can't remember so who knows. I know the Millenia one was fine... Guess I'll have to check after work.Check the PCV valve.... I have been though 3 in 30k!
