its been said a few times that they were hawks...
sometimes aftermarket pads work better, but dont last as long... and definitely when youre at a track using the brakes a lot to slow down from high speeds, its going to wear them fast...
P.S did the tread get ripped off the tires or did you have slicks?
cause it looks like you had slicks on the rear too. just curious
I'm sure am glad you are alright..
but im just not getting it..you had 3000 miles on the car and you had been to the track 3 times prior in which you burned through your brakes totally over that period of time? where they stock pads?
GDorris: I know you had the Hawk pads on, did the stock pads have a "squealer" pad wear indicator tab-thingy on them?
No mechanical wear indicator and no electronic pad sensor. You are right - there should be one or the other.
Problem is, there are too many nonstandard variations to account for. High traction slicks, aftermarket pads, high speeds, intense use over a short period of time, the list goes on. It's probably a combination of these factors that led to the combination of uneven wear and brake system confusion.
At the very least, this can serve as a warning to those who want to put some serious track time on their MS3.
