about to try and install my Catz. does anyone know where to feed the wires through the firewall?
ok. is there an easier way to hook up Catz? like tapping into the stock wiring as long as i have the relay?
i didnt see the hole :( maybe i'll try to grab the wire that comes out of the fogs and use that one instead of the drl wire
Look here. I guess its to the right and not under.
that's definately not there on mine. there is a metal piece about the same size covering it up w/ a line going to the brake fluid reservoir i believe it is. why would it be different on a p5?
o. i have a manual and i'm pretty sure jeg's is auto :( so where would i have to feed mine then. yikes
its ok, Chris showed me another spot. that black part on the edge of your pic. poke a hole and feed it through
I'm guessing automatic vs Standard?
The P5 uses a hydraulic clutch that ties into the brake master cylinder for fluid.
Matt
My car is a manual and has the empty hole there, I wired my amp power cable though it. Maybe its for cruise control (I don't have that) (shrug)
Put snow tires on her. :)
(eyeballs) You know it's only September, right? ...and that you live in Virginia, not Alaska, right? Oh, yeah, and that the P5 is FWD so all-seasons will get you around in that paltry excuse for snow that NoVA gets? WTF, SNOW tires?
