SLS has sold over 150 front motor mounts so far. 1 breaks and now they are bad!! You guys are amazing. As for the side motor mounts, Eric said they have sold close to 100 and have had 2 people break the bracket and not the mount. 1 breaks and now it's horrible.
Keep inmind that there are many factors that play into the stress that is put on the front motor mount. If your rear and side are blown out, then the front is going to now support the entire motor and it's movement. As for the side motor mount brackets that have broke, the one guy torqued them down so hard that it's cracked the aluminum. The other was from there original design and since was corrected. If installed correctly their mounts are great. My roomate and myself both run SLS mounts and have not had a single problem. Infact there are many people that have not had a single issue. 150 front mount and 1 breaks, is a very good ratio.
Where are the mod's at? Isn't this vendor bashing?
http://www.mazdas247.com/forum/showthread.php?t=123628663&highlight=mazda+forum+rules+guidelines
