well i got it off w/o the driver. did a trick w/ the old ac belt to keep it from movin. got it off w/ a breaker bar. guess i'll take the driver back to sears and tell them i want my money back. its craftsman and it did not satisfy me. i dont notice any significant difference in the timing though...idk i'll check again later today to see if i notice it
okay, i've been real remiss and not updating you all on the wonderfull items that she's received recently, sorry:
(thumb)
new air horn (the stocker pooped out last month)
new air diversion panel
new msp sterring wheel (received it last night)
new cork sport oil cap silver/black...cool beans!
new cork sport raidiator shroud...nice fo shua!
pics forth coming, with the new camera...i'll do a short video???
she deserves more....(sssh)(new 2003.5 msp bumper coming...woot, woot!!)
okay, i've real remiss and not updating you all on the wonderfull items that she's received recently, sorry:
(thumb)
you have a link to the raidiator shroud?
installed today:
Stock Pulley Weight: 5 lbs 0.6 oz
RR-Racing UDP Weight: 1 lb 6.4 oz
There are the weight specs for the two pulleys. RR-Racing's pulley weighs over 3 pounds LESS than the stock pulley, not to mention the smaller diameter of the pulley itself
Corksport Radiator Panel
Brand new product from CorkSport! The CorkSport Radiator Panel improves the look of you engine bay by covering the top of your radiator. The CorkSport Radiator Panel is made from FRP and comes gel coated black. The CorkSport Radiator Panel is ready to paint or it can be installed as is.
(thumb)
Nice Mark. The 03.5 bumper will look sweet on your car!
thanks jeff....ya, the dg lip is really too low for NE..the roads just plain suck! anyway, i'll sell the lip and use the original bumper for winter and the 3.5 in summer
The Newst thing ive done for my P5 was to join this forum. Looks like a good place to start the fun and games of moding my new car. I have a 2003 Yellow P5 with 72,000miles that i got for 7,700. allready was cold air intake Rally sport exhaust, Nice sound and i added Sirius radio. I want to add headers, rims and maybe new subs but thats down the road a bit. I happy i found you guys hope I can find some helpfull tips on makeing My P5 more (My P5)
Rooster From SPACEEEEeeeee......
Oil change... ordered RPF1s (thanks AUTORND, Rishie!!!), now I just have to order my tires. Probably some of the new Bridgestone RE-01R tires, they are massively grippy.
OOOOOooooo good choice! What size did you go with? I'm really torn between some 17x7.5 RPF1's (15 lbs w00t) or some 16x7 Gram Lites 57c's. Do you think 225/45R16's on a 16x7 wheel with a +46mm will work (I wouldn't mind rolling fenders). I really want something wider than 215 and unfortunately for 17" the next size up is 225/45 which is probably way to big (and heavy!).
nice score and welcome to the forums!
well, i didn't do it, but someone at my work customized my drivers side fender, right on the lip....(pissed)
sure!
http://www.thompson-automotive.com/Air_Horn.html
this was a really easy mod.
i have a mint blue grill so getting to the stock horn and replacing it may be easier that with a stock grill...? not sure, maybe bruce can chime in here?
anyway, i was able to reach in from the top and remove the bolt, disconnect the wire and pull out the stock horn in about 3 mins.
i used the bracket that come with the horn listed above and just turned in so the flat part would meet the frame, use the existing bolt hole, attached the ground to the stock bolt, attached the power lead to the + terminal...bolted it back on and i was done. i'll attache some pics tonight.
you need one wrench and about 30 mins start to finsh (even less)!!(cool) i love the sound as well!
Thanks a lot. This gives me a good idea of what I'm dealing with (rockon)
