So I cant afford new rims, and the stock ones don't look so bad.....but i don't like how they're inset so far. Would it be possible to put on 25mm wheel spacers, or is that too much? And if it is possible, would I be able to lower it any afterwards?
measure the distance from the tire sidewall to the inside of the fender
yes with 3-5mm you can use the stock studs...
25mm spacers you can get something like this
if you try 20mm spacers you may also be able to get away with the DRM style spacers depending if the cavities behind your wheel mounting pads are deep enough... or you could drill out larger cavities or shorten the studs
As shared by others, 25mm would be pushing it quite a bit.
I've also heard that spacers of that size can add wear to the car. (unconfirmed)
