where do you get a fender rolling tool like that?? my motor just went out a couple months ago and i decided to keep my p5 so i can turn it into a project car!!! oh and vg?? for the shark fin antenna?? im new to this so please dont think me as stupid. i think i want the rx8 wheels now too!
Got my amps mounted and all power/ground/rca's run and connected. System install is about 1/2 way done. Then comes tuning. woot.
www.Eastwoodco.com
Same one I used. :D Turns out the rubbing I was encountering was the tire just barely kissing the inside of the inner fender with the combo I am running now. (Which I only encountered with 4 of us in the car ... coming back with a full load from Costco lol). I've got front OEM P5 bump stops in the rear - which works great on the MSP, but you need about another 1/4" of bump stop on the P5 due to the more narrow rear fender wells. I had RX8 wheels - will you be running a 5mm spacer in the rear? 215/35 or 40/ 18's?
I am going to run RX8 Wheels as well....And I rolled the rears pretty damn good.
I am running 215.35/18's as well.
Why would I neeed to run a spacer in the rear..I had not planned on it?
Is there something I am missing?
Fill me in here?
Fill me in here?
Depends. What will you be using for struts? You will have no issues with clearance in the front; But if you are using an OEM style strut/spring combo, the RX8 wheels may be too close for comfort in the back and you'll need to bring them out a bit. With a 5mm spacer, they'll still fit under the fender without sticking out ... however, there's no getting around the fact that they are an 8" wide wheel which measures 9" from lip to lip.
Just pulled the trigger on an MP3 ECU. Wee bit more power and smoother powerband FTW!!!
Higher gas prices FTL!!!!
painting my valve cover, waiting for it to dry, then sand the letters back to silver!!! a lil bored today :)
