95blkprobe
- 95 Blk Probe/ 02 Blk Mica P5
So first thing first. I have an 02 p5 with a jdm fp-de installed. I had the car running n/a for about 3k miles. Car ran great with no problems. I then installed a factory turbo setup using:
msp ecu
msp s&j pipe
msp turbo
atp wg
all factory cooant and oil feed lines
10an return line
fmic with maf relocation and vented bov.
NGK 1 stage colder plugs gapped at .030 (these were for my big turbo install, but parted all that and went with stock boost and turbo)
msp oil cooler
always ran 93 octane since owning the car
I also have a boost gauge and wideband hooked up so I can monitor.
After buttoning the car together, i took it for a test drive and the car would make no power. AFRs and boost was fine (7psi). I then remembered my knock sensor was loose so i jst unplugged it to test my theory, it pulled good till a CEL would pop up (unplugged knock sensor). I took it all apart and tightened up on the knock sensor real good and it seemed to pull fine. I am now experiencing timing isuues on and off. the car seems to pull fine when its cold but on and off when its hot. I have an OBD2 bluetooth thing and the torque app on my phone and monitor timing this way. Sometimes it will get as low as -7.5 under full boost. When the feels right, it only gets as low as +7.0. The only CELs I have is primary o2 (idk why), secondary (I have my wideband in there and have an analog output from the gauge going to the ecu but it must need the o2 plugged in as well to see a complete circuit), and sometimes an evap code which is because I dont have it hooked up and never have. I have a ssafcv2 i still need to install as well but that shouldnt affect my timing issues, as i said before, my AFRs stay around 10.9-11.3 under full boost and wot.
I have read that the stock plugs should help, i checked mine after a 800 mile round trip and everything looks great. any ideas?
msp ecu
msp s&j pipe
msp turbo
atp wg
10an return line
msp oil cooler
