weird noise after sping install
ToNeZ90
2010 Mazda 3 Base Sedan
hey guys i just got eibach springs installed yesterday. All was fine untill this morning when i started hearing a noise from the driver-side front uspension. it sounds like eithe my caliper is rubbing or like air is leaking out. It does the sound in random intervals. Anyone know if its just the springs getting setled in?
okay here you go:
the red circle is highlighting the actual piece that is scraping. The red arrow is pointing out the part that actually touches the inside of the rim.
Again, the red arrow showing the part that scrapes, the green arrow is the nut ou need to loosen. Dont take it off, just loosen the nut, adjust the endlink support until it is completely up and down.
MY END LINK BRACKET IS ON THE BACK SIDE OF THE STEM BECAUSE OF THE WAY THE COIL OVER IS DESIGNED. YOURS SHOULD BE ON THE FRONT SIDE TOWARD YOU OUTSIDE OF THE RIM.
thanks man i got it fixed today. It ended up being the brake dust shield AND that end link
having the same issue on my gen1 after putting on RX8's however on my bracket where the arrow points, I have a metal weight there. so my passenger side ripped off but can see drivers side is rubbing.
doh i was checking the other forums and not here for this issue
Thanks
