TWM Short Shifter VS FULL Short Shifter Assembly
gtspec3
Hi guys,
Just picked an '08 Mazdaspeed 3 and I'm looking into the TWM short shifters - I've tried searching, but haven't seen a direct comparison on the full assembly vs the regular short shifter kit (unless it's hidden deep in some of the group buy sections), so I was wondering if you guys could shed some light on whether or not the full assembly is worth the cost or the regular short shifter does the job just right. Thanks for your time!
You might want to check out the SURE ShortCut and SURE CounterShift. I just did this and the shifts are significantly shorter. The shortcut simply changes the shift cable mount point and the countershift replaces the large stock weight with a much lighter one. Then add solid shifter base bushings (TWM, SURE, SU, etc.).
Similar Threads and Articles
