The gate keepers in the cooling system
2017 CX3 AWD
One thing that I have learned after a cooling disaster on my MINI is that by turning on the heater, the coolant in the heater core gets to mix with the rest of the fluid and helps bring down the temperature slightly.
Now that I am watching the temperature of the CX-3 more closely, I tried this and nothing happened. By turning the heater on max (max temp and fan, nothing sophisticated on my Touring). After five minutes of running like this at 65-75 mph, the coolant temp continued to fluctuate as if the heater was off. The heater was blowing hot though. Is this normal?
I am 80% positive that I tried this once last year and the temp went from 212 to 190 in stop and go traffic. There is a 20% chance that my memory failed me and that it was in the MINI.
Any insights are appreciated.
A lot of this has to do with the size of the engine.
In my experience (60 years driving), a larger displacement engine will maintain the engine temperature regardless of the heater settings. Lately however, this trend towards small displacement engines, and smaller coolant capacities, puts a little more strain on the cooling system, having to keep the engine at a steady level, while also delivering enough warm coolant to the heater core to warm the interior.
I know for a fact that the Honda 1.5L turbo CR-V has issues in cold weather. The engine takes forever to heat up, and the cabin heater and defroster drain any heat that might have built up from the engine. My brother in law had one of these, and it was brutal in our Canadian winters. You could let this thing idle for 20 minutes, and it would still be stone cold.
I don't know the particulars with some Mazda models (my 2017 Mazda 6 was fine), but I imagine any small capacity engine will have similar issues.
Thank you! I thought small displacement with small cooling system capacity would be faster to warm up. All my street cars are small displacement (2.0, 1.6, 1.1) so I always worry about overheating.
I feel that the cooling system is behaving differently from what I remembered. There are parts that I should replace before they fail, starting with the easy one, radiator cap. 😂 I am prepared for more though, car has 8.5 years and 166K miles.
The first car that I picked and owned independently was a 2009 Mazda5. After three years of care-free ownership, I moved onto a MINI and had many lessons to learn. The CX-3 has been drama-free until this May.
Your MINI no doubt had a heater valve the opened to allow hot coolant into the heater core. The displaced colder coolant then caused the temperature to temporarily drop as you have stated.
Our Mazda's (and probably all newer cars) lack a heater valve and coolant is continually flowing through the heater core at all times. The temperature is now controlled by the position of the blend doors.
Last year I pre-emptively replaced some cooling system parts on my 2014 at the 10 year mark. I used Mazda radiator hoses and thermostat. Thermostat was a chore and chose Mazda part because I don't trust aftermarket for such a critical item. Not worth risking overheat/engine damage. The original worked fine (and still did) for 10 years. Lot more parts to remove to change it compared to prior cars owned. The price for Mazda radiator cap was obscene (~$30) so I purchased a quality, made in Japan, "Sankei 555" brand cap for ~$12. Coincidentally, it was time to do 2X drain and fill of the coolant using ZEREX ASIAN formula coolant. The serpentine and water pump belts also got replaced with Mazda parts. At 10 years of service they needed replaced.
The valve cover gasket also got replaced because of a small amount of oil around the base of #1 spark plug before replacing the plugs also.
Thank you for confirming this! I believe the 1993 NA that I briefly owned was also like this, but I thought that was old tech. 🤦
Thank you! I am adding more parts to my list. For items that are easy to access and replace, I'd buy whatever I can get quickly on Amazon that has decent reviews. Otherwise OEM due to limited access to shop/help. The radiator cap (16 psi) that I ordered has a built-in temp sensor.
I searched for videos on thermostat replacement and watched a clip about coolant control valve which is in the vicinity. It made me anxious because I have never gone that deep. 😂
What is your coolant temp with Zerex Asian? I didn't use FL22 either.
The FL22 (according to these forums) Mazda later modified with a higher concentration to prevent corrosion. I don't have a way of knowing if non-Mazda fluids have accounted for that.
Can't see the coolant making any sort of difference in operating temperature since that's the thermostats job and have no idea what the coolant temperature is at any time unless I plug in my scanner, which isn't very often. Don't have any gauge readouts of any sort other than what came stock on the instrument panel. The coolant is clean and topped off and the car doesn't overheat. I don't give it much thought really.
I don't know either and I'm not particularly concerned for the following reasoning. Last summer when changing the thermostat and radiator hoses, the 4 year old Zerex from the previous service was clean and no buildup/deposits inside the hoses either. Prior to that ,the original factory fill was clean when drained at the 6 year mark. Recently checked heater core in and out temperatures and they agreed and the heater works well (well as good as it's gonna get but that's Mazda's design, same with the A/C which seems a bit weak sometimes). This discussion reminds me to get some pH test strips that I forgot about, so I can periodically monitor for changes. I guess we do what we can do.
Thank you, I didn't know that. I suppose the later/higher concentration formula is for newer models? The very old OEM coolant came out ok so I didn't collect a sample. Evidence of corrosion would be rust bits and etc?
There's no coolant temperature gauge on my dash board, only a two-digit display of ambient temperature. The OBDII scanner is the only way for me to find out. Seeing the number fluctuating is better than having a heart attack when the overheating light comes on. 😅 I understand, for diligent folks who are doing preventive maintenance, the numbers do not matter much.
I'll plead ignorance here as I don't remember much being posted in the past. My understanding is that some (must be a minority I'm guessing--never see much about it anywhere else) heater cores plugged and Mazda attributed it to corrosion and increased the amount of "something" in the revised formulation which supersedes the older formula ,so there's no specific individual older/newer versions. Judging that the health of my cooling system has always been good I choose to use a (what might be almost identical formulation) coolant from a long established manufacturer. What's to say that the Zerex is lacking in anti-corrosion additive compared to Mazda FL22. Or that Mazda's original formulation was deficient in some way and they rectified it. Too many questions so I just use what has been working for my CX-5 and it's a lot cheaper. Mazda seems to be rather "proud" of their branded stuff when it comes to pricing. NOW, when it comes to transmission fluid, it's Mazda FZ. No substitution there, at least for now.
You bring up a good point about the "heart attack" and I've had (or installed myself) gauges in some prior vehicles, so I'm not criticizing your choices. And I've actually thought about adding some sort of readouts for different parameters(engine and trans temps and oil pressure being the main 3), but never got beyond the thinking stage. This subject has now got my wheels turning again. Even with good maintenance, the ability to monitor and respond early to problems adds another level of safety and damage control to potential problems.
The app gives me two coolant temperatures, A and B. A is the figure that I am familiar with (ideally 194~212). B is higher than ambient, lower than A, and fuctuates similarly. Do we have two temp sensors for the cooling system? When Temp B was around 120, the lower rad hose was cool to the touch. When Temp B was at 185, lower rad hose was as hot as the upper hose. So far I have only been checking when the engine is off.
For the drive to work this morning, traffic was heavy. Temp B didn't increase much until much later into the drive. It climbed to almost as high as temp A in the last ten minutes (880N Oakland area).
Having watched a 3D animation on YT, I believe temp A is the engine side of coolant temp that gets hot quickly and stays hot (as well as the fluid in the heater core). Temp B is the radiator side, it starts out close to ambient and climbs gradually, not from coolant circulation but from heat in the engine bay (?). Coolant in the radiator joins in the circulation at a point that is not 180 or 194. The point where temp B started to rise drastically (meaning hot lava from the engine is getting mixed in, temp A was 200.
There seems to be a correlation between the speed and temp B. When the traffic slows and the speed drops, temp B goes up. Don't see much of a relation between load and temp B. Are both temp sensors analog/mechanical?
Edit to replace with better charts: first one is speed and Temp B. Second is absolute load value and temp B. Third one is temp A and B.
Temp B is from the radiator. I just checked after arriving at work and the reading on the cap is consistent with the OBD figure. The lower rad hose was warm, the top of the rad was cool to the touch, upper rad hose was hot hot hot. For this one-hour drive, coolant in the radiator wasn't utilized. Temp sensor, thermostat, or both? 🤦
My small OBD scanner has a temp1 and temp2. As far as I can tell, temp1 is the engine coolant temperature and temp2 is the coolant temperature leaving the heater core as measured by the sensor on the heater hose "manifold" on the passenger side firewall that both hoses attach to. Monitoring t1,t2, when engine warmed up, they will agree within a few degrees (I've had them read identical) and then t2 drops as expected when the heater fan is turned on.
So temp A is from the primary sensor near the thermostat. Temp B is from the sensor on the firewall near the heater core. Does A have anything to do with B?
In the typical Friday afternoon traffic on 101 South, I finally figured out how the cooling system works. Temp A shows coolant temp in the engine block. The thermostat is the first gate keeper in the system. It doesn't open until the engine gets up to temp at 180. It is mechanical and straight-forward. At 180 though, the hot coolant doesn't go straight to the radiator yet. There is a second gate keeper, the coolant control valve. As the brain of the operation, the ECU considers certain vital signs and determines when to open the gate to cool fluid. Speed seems to be one of the factors. If I am going at 50+ mph and Temp A is 194, Temp B fluctuates slightly. It was 70 before the slow crawl. However, if I am slowing down to 10 mph and Temp A starts to go up, Temp B would start to go up fast. It seems that a need to provide relief was detected and access was immediately granted. Temp B would go up to about 5 degrees below Temp A. When Temp A gets as high as 212, the fan kicks on and both figures start to go down.
After the episode is over (Temp A back to normal and speed is up), CCV closes the gate and the radiator starts to cool things down. It takes a few minutes before Temp B is down to 70~80. It will be ready to mix with hot lava at the next event.
The sensor for the cool fluid is located on the firewall, but the figure is the same as what is shown on the rad cap. There must be a reason for this, I hope to figure it out soon.
I am learning new things backwards. 😂 Someone is going to tell me that CX-3 doesn't have a CCV.
EDIT: The criteria for the CCV would include air flow. There are several sensors/values for the MAF and intake, they can also reflect the state of the vehicle as to whether temp relief is needed.
I can't find a second temp sensor on the firewall as I have seen on CX-5 in YouTube videos. I found the thermostat housing that is connected to the upper radiator hose. Not 100% sure if I identified the CCV correctly.
