Slim Fan ?'s
speedracr79
BAD WOLF
Contributor
Protege
Im looking to get some slim fans but not sure which i should get i know some pull some push some do both but which is better? Also what size are you running? I heard you can fit 2 12" fans but others have used a 10" and a 12". Which brand are you using? Basically any advice on the matter is appreciated.
Id like to get these because they match my radiator but
http://www.ebay.com/itm/Pair-TWO-Mi...&otn=3&po=LVI&ps=63&clkid=4937012982635612710
if these will get the job done then i can use the money saved elsewhere.
http://www.ebay.com/itm/JDM-UNIVERS...&otn=3&po=LVI&ps=63&clkid=4936976582249605169
Thanks
I have 2 10's pulling with the temp controller (ebay fans) I believe this is the best route to go.
