4 piston would be very nice, even in stock size. I would like to get a cross drilled rear rotor at the least. A vented slotted rotor would be preferred if that is possible with your kit.
Why would you want slotted or cross drilled rotors?
Too much heat on the rears. I've trashed my rotors in about 40k. The fronts are still ok though.
slotted won't help with cooling, but I was told that cross drilled would help a little. Firestone said that the rotors were really overheated and warped.
Why go through all that headache when you could just do a Speed6 brake upgarde.
http://www.*************.com/mazdaspeed8.htm
Looks nice but is front only... hmmm
