rims and tires
loweuro77
i am planning on ordering a set off 17x7 nzo alloywheels (turino), they have a 5/100 and 5/114.3 bolt pattern and was wondering if they will fit my yellow p5? also not sure what size tires to get, i keep reading about offset and stuff like that and dont know if that matters, if somebody could help me out it would be greatly appreciated.:confused:
Do you know what the offset of these rims are? Otherwise noone can help tell you if it fits.
first off...the bolt pattern on our cars is 5X114.3 so it has to have that pattern
the information below should give you what you need to know about the wheel offsets and the tires sizes you can use with that offset. also if you will go to this site http://www.miata.net/garage/tirecalc.html
its a tire size calculator which will tell you the differences between the stock size tire you have and any size you are considering...it will give you the differences and tell you how much your speedometer will be off if any.
this infromation is from Richie at
Automotive R & D
1626 Pomona Ave.
San Jose, CA. 95110
408-947-0505
Tire, Wheel, and Suspension Experts
Mazda Protege5 fitment guide
for tire sizes
215/40/17; 215/35/18
and rim widths of 7 and 7.5 the offsets need to be:
7.0" +45 and higher
7.5" +48 and higher
for tire sizes
205/40/17
7.0" +42 and higher; Barely making it
7.5" +48 or higher, the +45 still worries me with this width on a 205.
