Hi
I have a UK Mazda 5 Sport 2.0d. Recently the factory fit in-dash 6 disc multi changed stopped working - whereby the radio continued to work but the cd refused to acknowledge that there were any discs in it (there were) and would not allow you to load or remove any cds.
Today I decided to take the unit out to see if I could see anything glaring wrong with the cd mechanism. I removed the unit and had a look - nothing looked stuck or out of place so I reconnected it - this is where the problem started. After I reconnected all the plugs I turned the ignition on but the stereo refused to turn on - it's as if it has no power. Also now ever time you turn the ignition on:
- The air conditioning settings forget there last settings.
- The clock resets back to 13:00
- The speedo and other dials quickly spin right round to max and then resets back to 0. This never used to do this.
I'm worried what has happened - I didn't think removing the radio could have such an effect. I have tried disconnecting the battery but this has no effect.
Any help would be most appreciated.
Gromet
Gromet
