Problem with injen intake!
MP3_boy
2001 mazda MP3
i was checkin the oil in my car today and iwas checkin to make sure the intake was still tight and everything was alrite...
i was checkin the "vibramount" to make sure it was tight, and i came cross that the metal bracket was rubbin against the looks like AC/coolant tube (little one that runs under that mountin bracket) well the metal bracket has been vibrating and rubbin off the protective layer around the tube and looks like is wear away at the metal?
Can others with the Injen intake take a look at this to see if they are experiencing the same problem?
i'll try to get a picture of it later today
thanks
Shawn
picture of problem
here is a picture of the area with the problem..
look at the black covered tube and the metal bracket is rubbin on that
ok, checked mine... it just kinda lays on there, you say yours is RUBBING it?...i wonder how it would vibrate that much..:confused:
I actually posted this about 7 months ago on PC...Its simple to fix...just get some washers to use as spacers between the rubber spacer and the car...I think three did the trick for mine.
