Aftermarket headlight problems
Hello,
Just installed aftermarket Led headlights w/o AFS in a 2017 cx 5 touring sport. Everything is working good but now I have a headlight malfunction indicator on the dash in amber. They are compatible supposed to be plug in play. Matched part numbers.
Any suggestions or can't I use aftermarket? Also took through a car wash when done and they fogged up a little inside. Didn't think new headlight should do that. Would like some feed back if possible. Thanks!
Hey, did you find any solutions? I have exactly same problem after replacing my headlights to TYC ones with AFS
Can you pull the car codes? That would point yall in the right direction. I know some cars with incandescent bulbs will throw a code if you replace with led because it senses a different resistance value for the bulb and thinks that it's burnt out. Maybe that's it?
