Hi all,
I am new to this forum and recently purchased a 2006 Mazda5. Frankly, I was more interested in a 08-09 but came across the 06 with low miles (58k) and went for it. I did not realize all of the issues with the 06-07 models, and probably would have steered clear had I known. The vehicle has had typical suspension issues for an 06 (eating tires, shocks are shot, alignment issues, uneven brake wear)
Anyway, I really appreciate this forum and I have devised a plan to try to fix the suspension problem. Keep in mind this is a family car and my goal here would be to drive the vehicle for the next 100,000 miles without having to do any more significant alignment work on the car (hopefully this is possible). I'm willing to put a little more in up front in order to get my ride the way it needs to be.
This is my plan, and I would appreciate any feedback you may have. I'm no gearhead, so I will do the work myself when I think I can handle it, but am not willing to get in over my head:
1. Replace the rear struts myself (any advice on what to get that will last the longest? I do not want to lower the vehicle). I've seen the other threads but those seem more geared towards performance
2. Buy a Rear Control Arm Camber Kit online and have it installed. I will also have the front struts installed because it appears they would take a lot of work to do myself. I will pay a mechanic to do these at the same time rather than the alignment shop in order to save money (2 hours total?).
3. Have car realigned: camber at -.5 or maybe even 0 to save the tires. Toe in at 1/32 or again maybe 0. Willing to lose performance to save the tires.
4. Replace the front rotors myself (rear brakes are good).
5. Buy new tires (probably from tire rack). I do realize that I will have to replace these, but would like to think if I do all this, I will at least get the life out of these that I am supposed to. Suggestions on type? Stock size is fine unless there is a good reason to change it.
Thanks for reading...
