Some people had questions on using the alarm with the turbo timer, here is one answer. If you remove the "brain" for the alarm and unscrew the back, you will see four "dip switches" at the bottom of the circuit board. These are 1-2 off, 3-4 on. Simply switch 2 to on and your alarm will passively arm 30 seconds after the ignition is turned off. With the turbo timer, just lock the doors manually as you leave the car and when it shuts off the alarm will arm itself 30 seconds later.
I can post pics if necessary. Only problem is that the alarm will arm itself with the door open and the passive feature cannot be bypassed using the valet switch like with most alarms. I am working on a solution for that.
Britt
Britt
