P013B and preventative part cannonade
Hello,
My 2014 Mazda5 recently threw a P013B code (randomly).
According to information I found online, this is the upper O2 sensor getting old.
This is supposed to be intermittent, then it would become frequent, then would need replacement.
I'm planning to replace it right now, given that most of my drives are short distance and car doesn't warm up properly, which could contribute to this.
Now, the question is: do you have any such experience with this particular code: should the upper O2 sensor be replaced in advance, or should I wait longer?
If you replace it, only use OEM.
You sure it's the upper one? Isn't this code referring to the downstream one that comes after the cat?
I suppose it could be either one as I believe the ECM relies on both to figure out its efficiency.
Thanks for the heads-up! I think I picked this info incorrectly based on skyactiv engine comments somewhere.
It is indeed the one after the cat, and therefore, no need to do anything, I think. Could be just some condensation (very foggy recently).
Best to not fix it if it ain't broken.
The code is back and I re-read the internet again and come back with this question.
According to chatgpt: "P013B on a 2014 Mazda 5 (2.5L MZR) refers to HO2S-1 / Bank 1 Sensor 1, installed BEFORE the catalytic converter (on the engine side)."
Is there a way to double-check this against Mazda FSM or similar resource?
We live in a cursed location, where having Mazda dealership diagnose this would cost more than replacing both DIY. :|
Is there some sort of official source to check the codes against?
While researching online, I bumped upon a very detailed action diagram of what to check in what order for what code - but for Miata. I wish such thing existed for 5.
Actually, I found it! And you were right, it's the downstream sensor.
