^this
Also make sure that your drain line and fittings are large enough to give adequate flow as the outlet from the turbo is just gravity fed (well mostly). I have heard 1/2 inch.
You can also try to find an MSP bearing support tray (good luck), or get a spare bearing support tray and tap it, then put it on your block (not a quick job by any means).
So you may want to just go the tapped oil pan route, nothing wrong with it, just not ideal.
