New Wheels for MS6, need help!!
LugNuts
I was sad to learn I bent one of my wheels yesterday while driving on the craptastic freeways around Columbus. I want to replace all the wheels now with aftermarket ones; my top two choices right now are the Enkei Racing PFO1's or Performance Imola's. My fear is that the 18x8" will rub or cause other clearance issues. My car is lowered between 1 to 1.5" from factory height and I have rolled all four fenders although the rear fender roll is minor.
Does anyone have 18x8's on there car and can lend some ensight to my problem? Or does anyone know of other good wheels that are 18x7.5 that look good, are relatively light weight, and durable?
Thank you!
yes I have exhausted that thread but I have on question that is unanswered by it. what camber adjustments had to be made if any. I have no adjusted my camber at all from stock and i do not have the adjustable ball joints installed either. I dont know what the stock camber is in the front in rear??
if you know what it is, please enlighten me. I still have a lot to learn about this car...
After looking at that other thread I am more confident that the 18x8 will work, i just want to be 100% confident before I order them...
for me, and im sure most poeple, theres nothing worse than ordering a new part and then finding out you have to order three more in order to make the first work... specially now when money is tight!
you haven't provided half the info we need to help you...18x8 will fit but not with a 0 offset...what offset do you want?
