Need some help?
I wasn't all that impressed with the sub in the Speed. I mean, it's loud, but it sounds like it's only an 8". There's no real DEEP base to it.
So anyway, I was thinking of getting something simple to put in. I don't want nothing to big, and something that can easily be taken out.
So, I want to take The Kenwood WA100 Powered Sub ( One in my mp3) and hook it up in the Speed WITH the existing sub. After buying the speed, winter tires, rims, tint, front visor, turbo timer etc etc, I don't want to spend more money on more speakers yet
But, how hard is this going to be to setup? Getting the power hooked up seems to be the only difficulty. Is there an adapter that will split from the Speed's existing amp in the rear KAC-529S, and into the WA-100? The RCA jacks are a joke, but I don't know anything about these power connectors.
The MP3s sub has rca input and out puts so you could loop them though that. You should probably upgrade to an 8 guage wire atleast, if its not already in there if you want to run each sub. Easiest thing to do is just splice the power wire and remote wire off and ground them in the same place.
