I would like to change my tranny oil. What's the best oil? Synthetic or reg?
How hard is it to do? I can't find easy instructions..
Any good to know tips?
All help appreciated, car is ms6 btw
Use what the manual says. Although they don't always state it some ( not all ) oils that state they are correct for you transmission contain sulfur and other agents that can damage yellow metals. Most times you can find the location of the drain ( bottom) and fill plugs on autozones website.
You may want to change all three (MT, PTO, rear diff) while you're under there. Should only take a few hours. Personally, I used all Redline fluids and I've been fairly pleased with the results.
