MSP Cylinder Head Torque Specs?
JasonBourne
2003 Mazdaspeed Protege
Hi, I was searching for this information but didn't find it...What are the torque specs for the cylinder head studs?
step one : 16 ft lbs
step two : tighten each bolt 90 degrees
step 3: repeat step 3
found this on auto repair refference center
not sure how accurate it is, someone else can chime in?
in the step two, still using the torquimeter with 16 ft lbs???
and if step 3 it's the same that step 2 you tight 180 degrees in total?
you tighten all bolts to 16 ft/lbs, then turn each bolt 90 degrees and lastly turn each bolt another 90 degrees. per alldata
i get it, but the 90 degrees tight, have to be done with the 16 ft lbs?? or with a regular wrench?
isn't it repeat step 2?
lol yes sorry step 3 is repeat step 2
soooo your entire torque procedure would be
following the torque sequence bring them to 16 ft lbs then using a angle torque gauge(or a very good eye) turn each bolt a additional 90 degrees following the torque sequence, then repeat
it wouldnt be possible with the 16ft lbs. the bar would just keep breaking
the wrench will still click or break but your not going by foot lbs now, your looking for the degrees
when the wrench brakes you are still able to turn the bolt, its just over the setting the bar is at
alldata pic
