Mazda protege turbo question
d2r
2003 Mazda Protege
Anyone here know where I can get a stock oem turbo for my mazdaspeed protege or where I can find a turbo rebuild kit for it thanks.
you can get a rebuild from cross over auto. Its called chra replacement. Its almost not worth it though you might want to just buy a gt28rs.
Is the gt28rs turbo just plug and play or would have to get new piping and stuff for it. And where is the cheaps place I can get a gt28rs.
I would look around. Gt28rs should just be plug and play as long as you specify you still want a t25 flange. I would doible check before ordering though. Check cross over though
Do MSP owners not use Nissan T25s as replacements? The flange is the same, just journal bearing. There are a variety of compressor sizes with the Nissan T25 IIRC
i kinda think the bolt pattern is different for the spipe
Nissan T25's aren't a direct replacement, and the GT28RS isn't either. The 28RS has a larger intake inlet so you at least need an aftermarket intake with it.
