Looking for an engine
Jickywoo
2003.5 Mazdaspeed Protege
Looking for an enginge for my 2003 Mazdaspeed Protege. Blew the old one and have been searching around for a used one to put in.
No luck so far, was wondering if anyone on here had one or where I might find one.
Thanks
Also, can I just use a regular Protege engine and have the turbo put on? Will that function the same?
There is endless amounts of info on this question which can be found via search at top.
The engine (FS-DE) itself is the same. There are just a few parts you would have to add.
Windage Tray
oil/coolant return lines for the turbo
I believe an oil cooler? I'm not positive
If you have the time/money I'd suggest building the engine while it is out.
