chriscecc914
- 06 MS6
cant seems to find the one Im looking for
want to know what the best mod to do at first, what first part is worth changin
under 1k$
TMIC, cp-e ems, downpipe/catback combo all are under 1k each and give the best gains
under 1k$
ok just placed the order for a atp 3076r! any advise?
keep the bgoost low or you'll end up like me
why even get this turbo if you have to keep the boost down. It says on ATPs site "should only be used on this engine if you plan to exceed 450 crank HP (or go over 22 psi of boost)."
could you just swap the stock turbos actuator onto the new turbie?
all he said was the wastegate its set to 23psi not 18 psi, i dont know how to set it at 18 psi but ill find out!
manual boost controller....
you must get the ATP boost cut killer module too. just do it. no questions asked. if you don't you're just plain dumb.
No way
